Wall Mount for GL Routers (GL-MT300N-V2/ AR300M/ AR150/ S10)
by GL.iNet
Original price £8.50 - Original price £8.50
£8.50
£8.50 - £8.50
Current price £8.50
Type: GL-MT300N-V2/ AR300M/ AR150/ S10
⚠️Before You Buy
The Wall mount is for GL routers, please double-check to make sure the correct model before checkout.
The package includes:
  • 1 x Wall Mount
  • 4 x Screws
    • CPU:
    • Memory / Storage: /
    • Protocol:
    • Wi-Fi Speed:
    • Antennas:
    • Cellular:
    • Battery:
    • TF Card Slot:
    • USB Port:
    • Ethernet Port:
    • Ethernet Speed:
    • Power Input:
    • Power Consumption:
    • Dimension / Weight: /
    Product Initial Setup Guide
