PoE Splitter
Original price £14.60 - Original price £14.60
£14.60
£14.60 - £14.60
Current price £14.60
⚠️Before You Buy
Suitable for Comet, Comet Pro.
The PoE Splitter, featuring a USB Type-C output, is a compact device that allows you to power the Comet Pro using a PoE (Power over Ethernet) network. It separates the power and data from a single Ethernet cable, making it ideal for setups where traditional power outlets are limited or hard to access. It accepts a DC input of 36-57V and provides a 5V/2.5A output, compliant with IEEE 802.3af, while supporting data speeds up to 1Gbps.
  • Dimension / Weight: 90mm(L)x32mm(W)X27mm(H) / 100 g
  • 1 x PoE Splitter
Product Initial Setup Guide
