Travel Gadget Organizer Pouch Case | Hard Drive Bag | For chargers, cables, travel routers
by GL.iNet
Original price £15.99 - Original price £15.99
£15.99
£15.99 - £15.99
Current price £15.99
Color: Blue
⚠️Before You Buy
The best travel organizer for electronics! Hard Carrying Case replacement for GL-BE3600, GL-MT3000, GL-AXT1800, GL-MT1300, GL-SFT1200, GL-E750, GL-AR750S, GL-AR750, GL-MT300N-V2, and GL-AR300M. Perfect for travel, keep your devices organized.
Product Description:
  • Features: Case is made of supreme quality, durable EVA, crush resistant, anti-shock, water resistant material provides adequate protection from bumps, scratches and splashes.
  • With Internal mesh pocket can store other accessories.
  • Internal Dimension: 5.9 x 4.3 x 2.7 inch, External Dimension: 6.3x 4.7 x 2.8 inch
  • Durable Exterior Material: Polyester Fiber with soft pad inserted. The durable material can protect the device and accessories inside. The protection from the soft pad reduces the impact of falling and shocks.
  • CPU: N/A
  • Memory / Storage: N/A / N/A
  • Protocol: N/A
  • Wi-Fi Speed: N/A
  • Antennas: N/A
  • Cellular: N/A
  • Battery: N/A
  • TF Card Slot: N/A
  • USB Port: N/A
  • Ethernet Port: N/A
  • Ethernet Speed: N/A
  • Power Input: N/A
  • Power Consumption: N/A
  • Dimension / Weight: 16.2cm*11.8cm*6.9cm / 6.3in*4.7in*2.8in (L*W*H) / 138 g
  • A bag
Product Initial Setup Guide
