Spitz AX (GL-X3000) Wi-Fi 6 AX3000 | 5G NR | Dual-SIM failover | OpenWrt 21.02
by GL.iNet
Original price £340.99 - Original price £340.99
£340.99
£340.99 - £340.99
Current price £340.99
Style: US+UK+EU+AU plug
⚠️Before You Buy
GL-X3000 Wi-Fi 6 Cellular Gateway
MEET Spitz AX
Wi-Fi 6 Dual-SIM 4G/5G Cellular Gateway
Reliable Cellular Networks in Rural Areas
GL-X3000 is a Wi-Fi 6 cellular gateway designed to provide reliable cellular networks in remote locations and high speed internet in urban areas. It has six external antennas for long range connection, two SIM Cards for selecting between the ISP with stronger connections, and Multi-WAN between the WAN port, SIM Card, and Repeater.
Supports 5G NR & Multi-WAN
Dual-SIM, Single Modem
Wi-Fi 6 Max. 574 Mbps (2.4GHz) + 2402 Mbps (5GHz) Wi-Fi Speeds
OpenVPN speed up to 150 Mbps; WireGuard speed up to 300 Mbps
Learn More
Module: RM520N-GL
5G NR NSA n1/ 2/ 3/ 5/ 7/ 8/ 12/ 13/ 14/ 18/ 20/ 25/ 26/ 28/ 29/ 30/ 38/ 40/ 41/ 48/ 66/ 70/ 71/ 75/ 76/ 77/ 78/ 79
LTE LTE-FDD B1/ 2/ 3/ 4/ 5/ 7/ 8/ 12/ 13/ 14/ 17/ 18/ 19/ 20/ 25/ 26/ 28/ 29/ 30/ 32/ 66/ 71
LTE-TDD B34/ 38/ 39/ 40/ 41/ 42/ 43/ 48
LAA B46
UMTS WCDMA B1/ 2/ 4/ 5/ 8/ 19
GNSS GPS/ GLONASS/ BDS/ Galileo/ QZSS
Module: EM160R-GL
LTE LTE-FDD B1/B2/B3/B4/B5/B7/B8/B12/B13/B14/B17/B18/B19/B20/B25/B26/B28/B29①/B30/B32①/B66
LTE-TDD Intra-band and Inter-band
DL 2CA Intra-band and Inter-band
DL 3CA Intra-band and Inter-band
DL 4CA Intra-band and Inter-band
DL 5CA Intra-band and Inter-band within 5 bands
DL 4×4 MIMO B1/B2/B3/B4/B7/B25/B30/B32①/B38/B39/B40/B41/B66
DL 256QAM Supported
UL 2CA Intra-band
UL 64QAM Supported
UMTS WCDMA B1/B2/B3/B4/B5/B6/B8/B19
GNSS GPS/GLONASS/BeiDou(COMPASS)/Galileo
Notes: ①: For secondary component carrier only.
Recreational Vehicles(RV) Deployment
Spitz AX is your reliable router on the road, working in an RV. Spitz AX allows you to access multiple WAN connectivity, switching easily between the WAN port, SIM cards, and Repeater. It has 6 external antennas to increase connectivity. When an amplifier is needed for extra stability of your internet services in remote locations, Spitz AX can connect to an extended GPS antenna or wired dome antenna of your choice. To secure your secured network gateway on a bumpy ride, you can easily deploy Spitz AX to your RV's interior walls.
Dual SIM for selecting the ISP with stronger connections
Fast Wi-Fi 6 connection for all the devices in the RVs
Secure network when connecting to a public Wi-Fi
Reliable and Uninterrupted RV Internet
Spitz AX (GL-X3000) is equipped with advanced features, including Multi-WAN, Load-balancing, and Failover, to ensure RV users experience quality internet connections when traveling in both rural and urban areas.
Spitz AX is pre-installed with OpenVPN and WireGuard® supporting 30+ VPN services. It automatically encrypts all network traffic within the connected network, including guest or client devices that are not capable of running VPN. Spitz AX can also host VPN servers and supports VPN Cascading, automatically forwarding data from its VPN server to the VPN client within the same device.
WireGuard
Max. 300Mbps
OpenVPN
Max. 150Mbps
Our local network storage feature supports SMB Protocol and WebDAV protocol. By plugging an external USB hard disc into the router, you can create a private network to store and share your documents. No matter for work or family, you can benefit from easy file access. Save space on your devices by storing photos and videos on the network.
Spitz AX runs on GL.iNet's latest SDK4.0+ firmware and presents a user-friendly interface for common users to set up the router with minimal inputs, and an extended customization experience for advanced users to install plug-ins and applications. Spitz AX runs on GL.iNet's proprietary firmware based on OpenWrt (v21.02 Kernel version 5.4), supporting more than 5,000 ready-made plug-ins for customization. Simply browse, install, and manage packages with our no-code interface within the Admin Panel.
Everyday Scenario for Spitz AX
Remote Work
VPN cascading for you to access your company’s local server remotely
Rural Areas
Stable and long-range network connection using multi-WAN & antennas in your sizeable country house
Road Trips
Dual SIM cards to switch data services for your group in a snap
Co-working space
Secure your confidential data and network speed while using public Wi-Fi Services
Block Ads & Tracking for Free
AdGuard Home Ready on Router
AdGuard on admin panel
Block ads for all client devices
Block online trackers and analytics by default
Block age-restricted content and services as needed
Customizable DNS filters
Keep sensitive online data safe
Enforce family browsing security
PREVENT MAN-IN-THE-MIDDLE ATTACKS
DNS over TLS & DNS over HTTPS
Spitz AX supports both DNS over TLS and DNS over HTTPS to enhance network privacy and security, providing users with the flexibility to choose between encryption depending on the network type. DNS over TLS uses encryption to secure DNS communications, while DNS over HTTPS uses the HTTPS protocol for an additional layer of security.
Remote Access and Management
Spitz AX comes with GL.iNet's GoodCloud remote device & networks management platform, providing users with data usage monitoring and technical support services with remote access to the device admin panel for maintenance and troubleshooting. It also enables batch device management, firmware updates, analytics and notifications for status updates, enabling users to manage devices efficiently.
DFS Certification in US, CA, EU and UK
Spitz AX is approved to use DFS (Dynamic Frequency Selection), letting the router's 5GHz network use additional frequencies normally reserved by military, satellite, and weather radar applications. The selection of additional channels can lower network congestion under high density network environments.
Empowering IoT Connectivity with Customizable BLE, Thread, and Zigbee Integration
The Spitz AX offers IoT customization options including BLE, Thread, and Zigbee protocols. While customization is a key aspect of the Spitz AX, it is important to note that this feature is exclusively available for bulk orders.
Carrier Certified IoT Device
Spitz AX is certified by T-Mobile and AT&T under the IoT device category, and is therefore compatible with these network providers. Spitz AX’s IoT application is supported and interoperable with these network infrastructures, ensuring seamless connectivity and reducing the risk of connectivity issues.
Experience seamless connectivity with the Spitz AX, fully compatible with GL.iNet’s advanced eSIM solution, which supports both physical eSIM cards and integrated eSIM chips. eSIMs can be programmed remotely, offering unmatched convenience, flexibility, space-saving, and enhanced security. For consumers, this means effortlessly switching networks and avoiding roaming charges, while businesses benefit from centralized management, multi-device support, and secure data management.
Model Comparison
Spitz / GL-X750V2
4G LTE Smart Router
VS
Spitz AX / GL-X3000
Wi-Fi 6 4G/5G Router
QCA9531, @650MHz CPU MediaTek Dual-core, @1.3GHz
DDR2 128MB / NOR Flash 16MB Memory / Storage DDR4 512 MB / EMMC 8GB
IEEE 802.11a/b/g/n/ac Protocol IEEE 802.11a/b/g/n/ac/ax
300Mbps (2.4GHz), 433Mbps (5GHz) Wi-Fi Speed 574Mbps (2.4GHz), 2402Mbps (5GHz)
10/100Mbps Ethernet Speed WAN Port: 10/100/1000/2500Mbps
LAN Port: 10/100/1000Mbps
1 x WAN, 1 x LAN Ethernet Ports 1 x 2.5Gbps WAN, 1 x LAN
Max.512GB TF Card Slot Max.1TB
1 x Micro SIM card slot SIM Card Slot 2 x Nano SIM card slot
Max.10Mbps OpenVPN (Via Ethernet) Max.150Mbps
Max. 38Mbps WireGuard® (Via Ethernet) Max. 300Mbps
Spitz AX (GL-X3000) Reviews
  • Ultimate RV Internet Setup: Triple WAN Router Changes Everything
  • Why You Need a New Internet Gateway
  • Take your WiFi with you! GL.iNet Beryl AX & Spitz AX
  • THE ULTIMATE MOBILE INTERNET SETUP?
  • Our 5G Campervan WiFi Setup - With the GL.iNet Spitz AX Router (GL-X3000)
  • Don’t buy 5G Netgear M6 or RUTX50 without watching this first! Spitz AX GL-X3000 5G Router Review
  • AX Spitz 5G Router Review
  • Gl.INet GL-X3000NR overview
  • Notre solution INTERNET et WIFI dans notre camping-car !!! GL-X3000 SPITZ AX
  • MOBILE INTERNET Woes - New 5G Upgrade: Has it fixed it?
    5G NR Module
    *5G NR
    Module
    IoT
    #IoT
    OpenWrt Pre-installed
    OpenWrt
    Pre-installed
    Wi-Fi 6
    Wi-Fi 6
    VPN Client/Server
    VPN Client /
    Server
    AdGuard
    AdGuard
    MU-MIMO
    MU-MIMO
    DFS
    DFS
    * The Spitz AX is available in two versions: 4G LTE (CAT16) and 5G NR (CAT19).
    # Customization options are also available for bulk orders.
    The cellular feature in Spitz AX (GL-X3000) is restricted in Russia, Belarus, Cuba, Iran, North Korea, Syria, and the Crimean Peninsula due to modem limitations.
    • CPU: MediaTek Dual-core MT7981A, @1.3GHz
    • Memory / Storage: DDR4 512 MB / EMMC 8GB
    • Antennas: 4 x Cellular Antennas (SMA, 600M~6GHz), 2x Wi-Fi Antennas (PR-SMA, 2.4G~2.5GHz, 5.15~5.84GHz)
    • Cellular: 5G NR
    • Battery: N/A
    • TF Card Slot: Max.1TB
    • USB Port: USB 2.0 Type-A
    • Ethernet Speed: WAN Port: 10/100/1000/2500Mbps LAN Port: 10/100/1000Mbps
    • Power Input: DC5521, 12V/2.5A (5.5*2.1mm) [default adapter] / 9~36V
    • Power Consumption: <14W
    • Dimension / Weight: 155 x 95 x 36mm / 520 g
    • 1 x Spitz AX (GL-X3000) Router
    • 1 x Power Adapter
    • 2 x Wi-Fi Antennas
    • 4 x Cellular Antennas
    • 1 x Ethernet Cable
    • 1 x Warranty Card
    • 1 x User Manual
    • 1 x Wall-mount Kit
    Frequently Bought Together🎁
    Product Initial Setup Guide
    Custom HTML
