Brume 2 (GL-MT2500A) VPN Security Gateway with EU+UK plug | Aluminium Alloy
by GL.iNet
Original price £80.99 - Original price £80.99
£80.99
£80.99 - £80.99
Current price £80.99
⚠️Before You Buy
GL-MT2500 / GL-MT2500A
MEET Brume 2
Security Gateway for Remote Access
Powerful VPN Gateway for Home Office and Remote Work
Brume 2 (GL-MT2500/GL-MT2500A) is a lightweight and powerful VPN Gateway that runs on OpenWrt v21.02 operating system. It is compactly designed to host a VPN server at home, or run SD-WAN (Site-to-Site) for small and medium-sized enterprises.
Supports VPN Cascading
VPN Speed of 150 Mbps (OpenVPN) & 355 Mbps (WireGuard®)
Ideal for hosting VPN server
Learn More
VPN Cascading on Brume 2
Brume 2 is pre-installed with OpenVPN and WireGuard®, it supports running VPN server and client at the same time within the same device, enabling users to remote access local network resources like Wi-Fi printers or local web servers, and accessing the public internet as a VPN client at the same time.
Fast and Secure Browsing with OpenVPN and WireGuard®
Brume 2 comes with an open source based VPN solution, users can select from 30+ VPN service providers to optimize their network experience. It automatically redirects all network traffic within the connected network to your VPN service or server, including guest devices and client devices that are not capable of running VPN.
WireGuard
Max. 355Mbps
OpenVPN
Max. 150Mbps
30+ Commercial VPN services provider
Host Your Own VPN Server & Client at Home or Office
Brume 2 runs fast VPN speed which allows you to access your home network away from home securely and easily. It is equipped with a USB 3.0 port to provide a significant advancement in data transfer speed and give you the flexibility to upgrade your server storage whenever you want.
Runs on OpenWrt 21.02 Operating System
Brume 2 runs on open-source OpenWrt firmware, supporting thousands of ready-made plugins for customization. Simply browse, manage, and update packages within the router's Admin Panel.
Use Brume 2 together with the GL-M2 Development Board which is designed to connect you to a 5G network and give you the internet you deserve. With a built-in SIM card slot, the GL-M2 Development Board serves as a 5G modem for your router to get your internet up and running, whether you are residing in a remote area with no internet access or traveling on the road. Even better, the GL-M2 Development Board features multi-WAN, supporting failover and load balancing to keep you connected at all times.
Learn More
Incredibly Lightweight & Stylish design
Brume 2 comes in two versions: a frosted metabolic case and light weight plastic case made of ABS plastic.
Stylish
GL-MT2500A
GL-MT2500A
Aluminium alloy
VS
Best Value
GL-MT2500
GL-MT2500
ABS plastic
Staff working at home can access internal resources and sensitive information stored under a corporate private network via encrypted VPN tunnels.
Build your own VPN server with Brume 2. It provides a cost efficient way to access local files away from home securely and bypass geo-blocking.
Form a virtual office between head office and branch offices effortlessly and all the internal communications are protected by VPN encryption.
Block Ads & Tracking for Free
AdGuard Home Ready on Router
AdGuard on admin panel
Block ads for all client devices
Block online trackers and analytics by default
Block age-restricted content and services as needed
Customizable DNS filters
Keep sensitive online data safe
Enforce family browsing security
Brume 2 (GL-MT2500) Reviews
  • Video 0
    The SMALLEST VPN Gateway - GL.iNet Brume2
  • Video 1
    2023! Eigenes VPN gratis für die Reise mit FRITZ!Box oder GL.iNet Brume 2
  • Video 2
    Servidor VPN, AdGuard, TOR e Muito Mais! O Gateway de Segurança! | BRUME 2 (GL.inet GL-MT2500)
  • Video 3
    Neues von GL.iNET Brume 2 & Beryl AX // Man in the Middle Attack
  • Video 4
    Brume 2 WireGuard VPN Setup to connect with @SpaceinvaderOne
  • Video 5
    GL.iNet Flint 2 Multi-WAN Router Walkthrough VPN & Speed Test Review
VPN Client/Server
VPN Client/
Server
USB 3.0 Port
USB 3.0
Port
Tor Anonymity
Tor Anonymity
AdGuard Home
AdGuard Home
SD-WAN
SD-WAN
  • CPU: MT7981B Dual-core, @1.3GHz
  • Memory / Storage: DDR4 1GB / EMMC 8GB
  • Protocol: N/A
  • Wi-Fi Speed: N/A
  • Antennas: N/A
  • Cellular: N/A
  • Battery: N/A
  • TF Card Slot: N/A
  • USB Port: 1 x USB 3.0
  • Power Input: Type-C, 5V/2A
  • Power Consumption: <2.6W
  • Dimension / Weight: 70 x 70 x 22 mm / 157 g
  • Brume 2 (GL-MT2500A) security gateway (2-year Warranty)
  • Ethernet cable
  • Type-C power cable
  • User manual
  • 5V/2A Power adapter with a EU+UK plug
Frequently Bought Together🎁
Product Initial Setup Guide
