by GL.iNet
Original price £88.99 - Original price £88.99
£88.99
£88.99 - £88.99
Current price £88.99
⚠️Before You Buy
An Exceptional Wi-Fi 6 Experience
Wi-Fi 6's is a powerful upgrade in mass device connectivity and OFDMA data transmission efficiency technologies. On top of this, Wi-Fi 6 comes with a series of internet technology breakthroughs, including Beamforming for enhanced coverage and BSS Coloring for minimal network congestion.
Beryl AX (GL-MT3000) is pre-installed with OpenVPN and WireGuard® supporting 30+ VPN services. It automatically encrypts all network traffic within the connected network, including guest or client devices that are not capable of running VPN. Beryl AX can also host VPN servers and supports VPN Cascading, automatically forwarding data from its VPN server to the VPN client within the same device.
WireGuard
Max. 300Mbps
OpenVPN
Max. 150Mbps
70+ Devices Mass Device Connectivity
Wi-Fi 6's is a powerful upgrade in mass device connectivity and OFDMA data transmission efficiency technologies, letting Beryl AX connect with 70+ devices simultaneously. On top of this, Wi-Fi 6 comes with a series of internet technology breakthroughs, including Beamforming for enhanced coverage and BSS Coloring for minimal network congestion.
Smaller than your palm
An Engineering Masterpiece
Beryl AX comes with a 2.5G Multi-gigabit WAN port and a 1G gigabit LAN port, it is capable of processing network and VPN packets efficiently using its MediaTek MT7981B 1.3GHz Dual-core processor. The router also comes with a Type-C power supply and a USB 3.0 port for external storage.
Beryl AX's latest SDK4.0+ firmware presents a user-friendly interface for common users to set up the router with minimal inputs, and an extended customization experience for advanced users to install plug-ins and applications. Beryl AX runs on open source OpenWrt 21.02 (Kernel version 5.4) firmware, supporting more than 5,000 ready-made plug-ins for customization. Simply browse, install, and manage packages with our no-code interface within Beryl AX's Admin Panel.
Access Your Local Network Storage
Our local network storage feature supports SAMBA and WebDav protocol. By plugging an external USB hard disc into the router, you can create a private network to store and share your documents. No matter for work or family, you can benefit from easy file access. Save space on your devices by storing photos and videos on the network.
DFS Certification in US, UK, Europe & Japan
Beryl AX is approved to use DFS (Dynamic Frequency Selection), letting the router's 5GHz network use additional frequencies normally reserved by military, satellite, and weather radar applications. The selection of additional channels can lower network congestion under high density network environments.
WPA3 protocol
WPA3 protocol
DNS over HTTPS & DNS over TLS
AdGuard Home
AdGuard Home
IPv6
IPv6
Use Beryl AX together with the GL-M2 Development Board which is designed to connect you to a 5G network and give you the internet you deserve. With a built-in SIM card slot, the GL-M2 Development Board serves as a 5G modem for your router to get your internet up and running, whether you are residing in a remote area with no internet access or traveling on the road. Even better, the GL-M2 Development Board features multi-WAN, supporting failover and load balancing to keep you connected at all times.
Model Comparison
Opal (GL-SFT1200)
Opal
(GL-SFT1200)
Gigabit Wireless Router
Slate Plus (GL-A1300)
Slate Plus
(GL-A1300)
Gigabit Travel Router
Beryl AX
(GL-MT3000)
Wi-Fi 6 Travel Router
CPU SF19A28, Dual-Core @1GHz IPQ4018, Quad Core@717MHz MT7981B Dual-core@1.3GHz
RAM DDR3 128MB DDR3L 256MB DDR4 512MB
FLASH SPI NAND Flash 128MB NOR Flash 4MB + NAND Flash 128MB NAND Flash 256MB
Gigabit Port 2.5G
Wi-Fi Speed 300Mbps(2.4GHz),
867Mbps (5GHz)
400Mbps (2.4GHz),
867Mbps (5GHz)
574Mbps (2.4GHz),
2402Mbps (5GHz)
MicroSD Slot
USB Port USB 2.0 USB 3.0 USB 3.0
OpenVPN
(Via Ethernet)
Max. 21Mbps Max. 28Mbps Max. 150Mbps
WireGuard®
(Via Ethernet)
Max. 65Mbps Max. 170Mbps Max. 300Mbps
Beryl AX (GL-MT3000) Reviews
  • Video 1
    Travel Routers Improve Your Life! Beryl AX Complete Setup
  • Video 2
    I didn’t know I needed this - GL.iNet Beryl AX
  • Video 3
    WiFi 6 Travel Router with Wireguard & OpenVPN : GLI.Net BERYL AX3000
  • Video 4
    Neues von GL.iNET Brume 2 & Beryl AX // Man in the Middle Attack
  • Video 4
    [Unboxing] Beryl AX Wi-Fi 6 Router (Model GL-MT3000)
  • Video 4
    Travel with WiFi 6 - GL-iNet Beryl GL-MT3000 WiFi 6 Travel Router Review
  • Video 4
    GL-iNet Beryl AX WiFi6 AX3000 Travel Router Overview & Speedtest (GL-MT3000)
  • Video 4
    O MINI ROUTER que é MELHOR que o Router da OPERADORA! (VPN, Adguard, TOR) | BERYL AX (GL-MT3000)
  • Video 4
    Beryl AX GL-MT3000 Wi-Fi 6 & 2.5G Travel Router Review - INSANE $99 Router?
  • Video 4
    Beryl AX3000 Router Review | Fastest Router I've Ever Used! Up to 500+ Mbps on Wi-Fi 6!!!
  • Video 4
    Beryl AX Review en ESPAÑOL | El mini router VPN más POTENTE del mercado
  • Video 4
    Tiny Router Showdown - 2.5G, Tethering, and Docker?
  • Video 4
    GL iNet Beryl AX-Faster, More Compact, & 70+ Wireless Clients
  • Video 4
  • Video 4
Wi-Fi 6
Wi-Fi 6
2.5-Gigabit Multi-Gig port
2.5G
Multi-Gig port
VPN Client/Server
VPN Client /
Server
USB 3.0 Port
USB 3.0
Port
OpenWrt Pre-installed
OpenWrt
Pre-installed
AdGuard Home
AdGuard
Home
DFS
DFS
Network
Storage
  • CPU: MT7981B Dual-core Processor @1.3GHz
  • Memory / Storage: DDR4 512MB / NAND Flash 256MB
  • Antennas: 2 x retractable external Wi-Fi antennas
  • Cellular: N/A
  • Battery: N/A
  • TF Card Slot: N/A
  • USB Port: USB 3.0
  • Power Input: Type-C, 5V/3A
  • Power Consumption: <8W
  • Dimension / Weight: 120 x 83 x 34mm / 196 g
  • 1 x Beryl AX (GL-MT3000) Router
  • 1 x Power Adapter with US+EU+UK plug
  • 1 x Ethernet Cable
  • 1 x Warranty Card
  • 1 x User Manual
Frequently Bought Together🎁
Product Initial Setup Guide
