FREE UK domestic shipping on selected hot items
by GL.iNet
Save £9.90 Save £9.90
Original price £67.80
Original price £67.80 - Original price £67.80
Current price £57.90
£57.90 - £57.90
BEFORE YOU BUY
  • Enjoy FREE SHIPPING on UK local deliveries, with an estimated delivery time of 3-7 working days.
  • Products without the "UK local delivery" tag are shipped from outside the UK and are subject to shipping costs & longer delivery time.
Bulk Order
Slate Plus (GL-A1300) is a Wi-Fi 5 pocket-sized travel router with a powerful CPU optimized for network stability and processing VPN encryption efficiently. It includes our latest security features and runs on the latest OpenWrt operating system. It is designed for frequent travelers who have a heavy demand on using VPN networks.
Product Description:
  • Dual-band AC Wireless Router: Simultaneous dual-band with wireless speed 400Mbps (2.4GHz)+867Mbps (5GHz).
  • Runs on OpenWrt 21.02: Slate Plus runs on OpenWrt 21.02 operating system, with mass device connection capabilities, and significantly reduced signal interference.You can customize the router and install applications based on your preferences.
  • Support OpenVPN and WireGuard: OpenVPN and WireGuard pre-installed, compatible with 30+ VPN service providers. Max. VPN speed of 28Mbps (OpenVPN); 190Mbps (WireGuard).
  • CPU: IPQ4018 Quad Core, @717Mhz
  • Memory / Storage: DDR3L 256MB / NOR Flash 4MB + NAND Flash 128MB
  • Protocol: IEEE 802.11a/b/g/n/ac
  • Wi-Fi Speed: 400Mbps (2.4GHz), 867Mbps (5GHz)
  • Cellular: N/A
  • Battery: N/A
  • TF Card Slot: N/A
  • USB Port: 1 x USB 3.0
  • Ethernet Port: 1 WAN port, 2 LAN ports
  • Power Input: Type-C, 5V/3A
  • Power Consumption: <6.5W
  • Dimension / Weight: 118 x 85 x 33 mm / 181 g
  • Slate Plus(GL-A1300) (2-year Warranty)
  • USB cable
  • Ethernet cable
  • User manual
  • 5V/3A power adapter with EU+UK plug
